Data protection Strategy
What would be best data protection Strategy.
Raid 1 the Work folder + Sync to external USB + Cloud daily sync
Or
Sync work folder to USB Hard Drive + NAS with RAID 1 + Cloud daily Sync
Basically want to know where is the best place the RAID 1 should be placed , on the work folder or on the backup
I vote for ALL OF THE ABOVE!!!
I doubt it would matter much unless the NAS could be setup with a wireless connection in another part of the building.
Think about Fire and Theft when creating a backup plan. If the fire starts in you main computer room - you don't want your backup to all burn.
I don't have the budget to do both .,.the second option requires me to buy a NAS....so there is no real PROS/CONS of if.use the MOBO RAID on primary.data set vs NAS RAID on the secondary data set....as long as it use somewhere?
The both part was a joke....
You're wanting to backup your data.... A copy sent to a USB Drive and a copy to the Cloud would be fine for most people.... Raid 1 is over rated...
Cloning your hard drive and keeping that at another location is something to consider.
new here, ramdom forum to post
