What method do you use to redirect a page ?
Printable View
301 redirect page is the method we use to redirect a page
301 ridirection
A redirect is a way to send both users and search engines to a different URL from the one they originally requested. The three most commonly used redirects are 301, 302, and Meta Refresh.
Types of Redirects
• 301, "Moved Permanently"—recommended for SEO
• 302, "Found" or "Moved Temporarily"
• Meta Refresh
301 Moved Permanently
A 301 redirect is a permanent redirect which passes between 90-99% of link equity (ranking power) to the redirected page. 301 refers to the HTTP status code for this type of redirect. In most instances, the 301 redirect is the best method for implementing redirects on a website.
Most of website use 301 redirects to redirect page
By solving the 301 redirect page or 302 or 404 depends on your method.
301 is a permanent redirection we use whereas
302 is a temporary redirecton
If you wants that search engine pick up on redirects quickly then do server side redirects. The uses of 301 redirects will be moved permanently and the uses of 302 will be moved temporarily.
301 Redirect
I use 301 Redirect Method.
