does pro stores support international sellers ?
Does prostores support international selles ? specificly Egypt ?
and i would like to kow your opinion about pro stores ?
and iam wondering how can i contact prostores online without signing up ??
There should be contact information on their website. If not, then I would not even bother to consider them.
International
I do not have a lot to compare to, but PS works reasonably well for international sales.
You as the Admin need to set up shipping rates to international because - and this is important - PS does NOT interface with USPS for shipping rates directly. This means that when a customer purchases, the PS software will try (unsuccessfully) to get rates from USPS, not recognize them, and default to your shipping tables. If you have set up the buyers country specifically (say, Egypt) then it will pull rates from that table. If not, it will pull from the default table, not always accurate.
Either way it is workable.
In general, I think PS is a so-so platform. There are several excellent features, but some that are absurdly bad. Two come to mind: 1) their customer support is terribly inadequate. If anyone tells you otherwise, do not believe them.
2) I am starting to see indications of poor search capability. Part of this may be due to an EBay mentality where they change the software constantly and create problems. I am not a savvy search person, so I may be wrong. However, I have seen enough comments on this to think there is at least some substance to it.
If you have a 3rd party build your site for you (I used Neoverve) they can assist you with many tech issues. I know I would have been lost if I had to rely on PS.
Hoe that helps.
Brian
www.atomic-moto.com
[email protected]
