is there a solution behind ebusiness portals like open english?
if I want to build an e-commerce site to sell products online I know that I can use solutions like Wordpress with woocommerce.
Is there a solution that helps build a portal that sells products or services from others, like Open English that sells courses from various academies or amazon that also sells products from many different vendors.
If I want to use Wordpress to build the front end of such a solution (using woocommerce to build the shopping cart like solution), what else do I need to easily connect my site with other sites in order to offer other product or services through my site?
Thanks in advance,
Rafael
Yeah you can do it just get proper RND fist then go on...
You can simple join their affiliate marketing program and offer their courses on your website.
